2003 Saturn L300 Failed State Inspection
2003 SATURN L300
105,000 MILES • 6 CYL • FWD • AUTOMATIC
JERICE58
Diagnostic Codes P0740, P1860, P0700 - what normally would be done to fix this and what would be the estimated cost.
Sep 16, 2010 at 3:00 PM
ERNEST CLARK
  • 1,730 POSTS
P0700 code means the power train control module (computer) has received a message from the transmission. There's no "P0740" code. There is however a "P0741". This is for a Torque Converter Clutch (TCC) solenoid. The P1860 is for the TCC circuit.
What this means is either the valve has failed or the wiring/connector to the valve has failed. Only an inspection will tell for sure.
Labor will be between 4-6 hours at anywhere from 60-120 per hour, depending on the shop. I can't locate the price of your part right now, but it's sure to cost 100-200, also depending on where you get it.
Sep 25, 2010 at 4:50 PM
