2001 Saturn L300 Takes forever to start
2001 SATURN L300
166,666 MILES • 6 CYL • AWD • AUTOMATIC
AMEMUS
Mechanic isn't sure, computer says it is misfiring. Sometimes it will start 2nd or 3rd try sometimes 30 minutes trying. The part(throttle actuator control module he would like to try is $500 for part only and he isn't positive that is it. "they are stumped" . We have done all the maintenance that was suggested and the car has run very well for 10 years. I searched the internet and there are alot of unhappy people out there with this particular car and having many more problems. I was hoping to get a couple more years out of it. Please help. Thank you
Apr 9, 2010 at 6:05 PM
LEGITIMATE007
  • 5,121 POSTS
lets look for a few things, first I want you to look for vacuum leaks,, you can spray some brake kleen without the little straw, around and in back of the intake maniflold, while the car is running, if there is a change in idle then you have a leak in that area. also check the accordian tube going from the air filter box to the throttle body for cracks leaks etc. then change your pcv valve and check the mapp sensor keep me posted
Apr 9, 2010 at 6:35 PM
AMEMUS
the codes that came up are
P0606
P0202
P1519
the mechanic has looked for leaks
thank you
Apr 12, 2010 at 8:51 AM
LEGITIMATE007
  • 5,121 POSTS
202-injector circuit malfunction, there is your misfire, along with that comes 1519 malfunction in the idle air control valve circuit. and 606- pcm processor fault. so you will need to check the cylinder number two injector circuit, wiring could be frayed etc. and check the idle air control valve circuit before haveing to get your pcm"flashed" or replaced because of code-1519
Apr 12, 2010 at 10:56 AM
