My car has a DOHC. There isn't a throttle cable, in stead I have a sensor on the gas peddle and a motor on the throttle body.
While I am driving my car will suddenly stop responding to the gas peddle. The Rpm's will drop and I start costing. If I turn the engine off and restart it I can go for another mile or so and then the same thing happens. i am getting the following engine codes.
P1271 - Accelerator Pedal Position Sensor fault
P0101 - Mass air flow error - Auto Zone Ticket describes a possible TPS problem
P0403 - EGR - I know this went bad
P0405 - EGR - Same
P0341 - Camshaft position sensor out of range
P0107 - MAP Sensor error
I think I got some incorrect info about the TPS. Do you have any suggestions?
Thank you for the help
Jan 28, 2009 at 6:05 PM
