2003 Saturn L200 Engine Struggling
2003 SATURN L200
82,000 MILES • 4 CYL • FWD • AUTOMATIC
QKELLY
Hello
My car seems to be "struggling" when I try and accelerate. It always does, but I notice this when I drive uphill also. It almost feels like the fuel is having trouble reaching the engine. I had a new fuel pump put in last month.
The check engine light is NOT on, and I recently put in a new air filter and fuel injector cleaner. I also had my catalytic converter replaced by the dealer in 2007.
Any advice?
Thank You
May 17, 2010 at 8:59 AM
If your transmission is not slipping-do below:
Inspect and test all the following listed below and get back with some results
Oxygen sensor.
Catalytic converter.
Fuel injectors dirty/sticking.
Mass airflow sensor/Airflow meter.
Throttle position sensor.
Manifold absolute pressure sensor.
EGR Valve
Fuel pressure regulator leaking or defective fuel pump.
False air leakage.
Fuel contamination.
Foul/defective spark plugs.
Open spark plug wires.
Ignition coil/Coil packs defective.
Incorrect ignition timing.
Cap and rotor.
Note:If it doesn't apply disregard.
May 20, 2010 at 3:57 AM
