Electrical problem
2003 Saturn L200 4 cyl
Hi i recently worked on my vehichle to try and get my a/c working.
At first i had no refrigerant in system because of condenser and radiator being replaced, however, i filled about 2 12oz of 134a into system with vehicle ac compressor on. I could not find any leaks, gauge never read filled.... however during charging the system, compressor clutch started to jump and jump...me and a friend jumped the high pressure sensor and stayed on.
A/c relay was tested and was fine.
During all of this the compressor clutch would jump with ac button on and pull a load, low idleing.
I had a battery issue after this and my alternator had to be taken in.
- I had someone replace a regulator on it that went bad
Car runs but battery indicator light still stays on without Air condioner running
All fuses are ok , maxi's , relays.
What could be the problem???? Alternator fusible link??? Please Help
Apr 8, 2010 at 5:05 PM
