2002 Saturn L200 water leaking in floor board
2002 SATURN L200
102,000 MILES • 4 CYL • 2WD • AUTOMATIC
ROSSGARZA
Water is leaking from middle counsole making the carpet super wet. Only when running the A/C.
May 2, 2010 at 6:01 PM
SATURNTECH9
  • 30,869 POSTS
If the water is clear and just water not coolant then u have a clogged a/c drain an will have to clean it out.the drain is located in about the middle of ur fire wall it has a tube hole for the water to come out and and bolt that holds it in place it's the only thing that looks like that.take the bolt out and them take out te drain and clean.u will leak slot of water.let me know how it goes.
May 3, 2010 at 1:45 PM
