I can not make my AC work. Checked the fuses, relay is good. Jumped the relay connection and the compressor runs and cools great. (contemplating a toggle switch)
I am pretty sure I have a bad temp sensor in the Auto Climate Control or maybe the Climate Control Panel is screwed up. I am thinking maybe the temperature sensor is not the culprit as the AC won't cycle on defrost either.
Have to be a genius to "test" the CCP, but wouldn't mind taking a chance replacing it if someone knowledgeable told me that CCP failure is a common problem. Was hoping for thoughts and what you'd try next. Also, if you knew of a wiring diagram link, that'd be swell.
Apr 7, 2010 at 9:19 AM
