2002 Saturn L200 A/C condensate drain
2002 SATURN L200
165,000 MILES • 6 CYL • FWD • AUTOMATIC
BOBBY.CONDITT
The passenger side floor board is getting really wet from condensate leaking inside
Jul 22, 2010 at 8:13 AM
SATURNTECH9
  • 30,869 POSTS
Sounds like you have a clogged a/c drain look on your firewall about half way down towards the middle you will see a tube.There's a bolt holding it in remove the bolt and then remove the drain tube then clean it and put it back in.
Jul 22, 2010 at 1:52 PM
