2001 Saturn L200 when hot outside, car slams into gears wit
2001 SATURN L200
115,000 MILES • 6 CYL • FWD • AUTOMATIC
BEVTHOMPSON
This happened last year during the heat of the summer and no mechanic could find a problem with my car. When it get shot outside and I am driving with the air on (typically after IU have driven 5-15 miles) my car will rev up higher between gears and then "slam" into the next gear-it jars the entire car. I tried turning off the air and turning on the heat, as well as rolling down the windows- and it seems to lessen the severity. The thermostat never quite reaches the halfway mark and the engine does not steam or anything upon cutoff, so I do not think tha tit is overheating. It just did it Friday (temp of 86) and I am thinking "here we go again". Please give me some suggestions. Thank you so much.
Apr 5, 2010 at 12:16 PM
SATURNTECH9
  • 30,869 POSTS
[quote:8cf236772c="bevthompson"]Transmission problem
2001 Saturn L200 6 cyl Front Wheel Drive Automatic 115000 miles
This happened last year during the heat of the summer and no mechanic could find a problem with my car. When it get shot outside and I am driving with the air on (typically after IU have driven 5-15 miles) my car will rev up higher between gears and then "slam" into the next gear-it jars the entire car. I tried turning off the air and turning on the heat, as well as rolling down the windows- and it seems to lessen the severity. The thermostat never quite reaches the halfway mark and the engine does not steam or anything upon cutoff, so I do not think tha tit is overheating. It just did it Friday (temp of 86) and I am thinking "here we go again". Please give me some suggestions. Thank you so much.[/quote:8cf236772c]
first of all thank u so much for ur donation it really helps to keep this site going and answering everyones questions.have ur codes scanned at a auto parts store and let me know what codes u have.sounds like a pressure problem in ur transmission though.
Apr 6, 2010 at 5:31 PM
