2001 Saturn L200 Timing Chain Replacement
2001 SATURN L200
53,000 MILES • 4 CYL • 2WD • AUTOMATIC
ROKCOPAYIM
IYH I'm purchasing a 2001 Saturn L-Series with 53,000 miles. The biggest complaint on carcomplaints.com is the timing chain breaking and causing expensive damage to the engine.
1) Is it wise to have the timing chain changed immediately upon receiving the car, or should i wait for some sound or indication that trouble is coming.
2) Is there any way to tell by looking at the engine - if the timing chain has already been replaced?
Nov 2, 2010 at 2:18 PM
SATURNTECH9
  • 30,869 POSTS
First of all thank you so much for your donation.You are right there are alot of problem's with the timing chain's in the early saturns they had issue's with there timing chain tensioner's chain's jumped and broke.There is no way of telling by looking at the engine if it was changed.There was a campaign where saturn changed the chain on some of them for free.I would go to a chevy dealer and see if they can do what is called a nvh which is a national vechile history search to see if the chain was replaced under the campaign.You would need the last eight of the vin to have them do that.
Nov 2, 2010 at 2:36 PM
ROKCOPAYIM
Thanks, but my main question is (supposing I verify that it hasn't been changed) - whether to replace it right away or to wait until some point (& if so which point)?
Nov 2, 2010 at 2:41 PM
SATURNTECH9
  • 30,869 POSTS
If you find it hasn't been changed then yes i would change it as soon as you can there is no warning for failure.I would see if the timing chain campaign has been done though if it hasn't then there is a chance you could get a free chain replacement.
Nov 2, 2010 at 2:47 PM
ROKCOPAYIM
Ok - thanks. I'll try to let you know what happens, IYH.
Nov 2, 2010 at 2:50 PM
SATURNTECH9
  • 30,869 POSTS
Here's the last eight of the vin range that has the affected timing chain's if it's within 1Y504884 thru 1Y559453 then that car has the faulty timing chain and has the recall on it.
Nov 2, 2010 at 3:10 PM
