2001 Saturn L200 The same problem
2001 SATURN L200
80,000 MILES • 4 CYL • 2WD • AUTOMATIC
RUSSO_02
  • 4 POSTS
I have the same problem with my saturn. But I not something If I turn off the A/C the over heating stop.
I turn off the car and then turn on and the fan turn on.
I have other problem in some cases the transmission shifting start with timing problem but I turn off the car and then turn on and stop with the problem. Those problem sounds strage. If somebody can help us I will appreciate that. What we can do to repair these problems?
Oct 12, 2008 at 3:38 PM
JAMES W.
  • 2,394 POSTS
Sounds like the fan control temp sensor is faulty.
As far as the transmission problem, I'm not sure what you mean. Can you be more specific?
Oct 12, 2008 at 9:49 PM
RUSSO_02
  • 4 POSTS
Mr. Weizel,
Thank you for your promp reply. Could you please let me know where this fan control temp sensor go?
Thank you in advance and best regards,
Oct 13, 2008 at 10:43 PM
RUSSO_02
  • 4 POSTS
In regard to the transmission problem the following statements are the steps;
- The car run perfect.
- Sometimes after running perfect start with shifting problem.
- I'm turn off the car.
- Wait 5 sec.
- I'm turn on the car.
- The car start running and in the first shifting change very hard
- Then the car continue running perfect.
This sounds very strange but its happened. I will appreciate your comments.
Thank you and best regards
Oct 13, 2008 at 10:53 PM
JAMES W.
  • 2,394 POSTS
Temp sensor is on the thermostat housing. the thermostat housing is on the motor where the upper radiator hose attaches.
On your transmission problem. What you need to do is locate a shop or dealership that can "scan" your transmission control module. If you can find out the memory code is, and what it says, we can go from there.
Oct 14, 2008 at 7:54 PM
