2001 Saturn L200 heater wont work
2001 SATURN L200
DAWN72LUV
Heater problem
2001 Saturn L200 4 cyl Front Wheel Drive Automatic
I have changed the blower moter for my heater and am now woundering were the relay is on this car for the heater
Sep 14, 2010 at 8:56 PM
SATURNTECH9
  • 30,869 POSTS
Let's start with what's going on with your car like does the blower motor totally inop or is it in inop in certain speed's etc?Let me know so i can help you out with your problem.
Sep 14, 2010 at 11:16 PM
DAWN72LUV
At first it only worked intermitently on all settings then it quit all together there is nothing.
Sep 15, 2010 at 3:00 PM
SATURNTECH9
  • 30,869 POSTS
Look in the under hood fuse box see if the number 7 30 amp blower hvac fuse is blown. Do you still have the have blower motor cover off?If you do take a multimeter and check the black wire going to the motor and see if you have 2 ohm's or less going to ground.If you don't have the cover off then go to the back of the blower switch and check the orange wire with the key in the run position and the blower switch on high you should have battery voltage to that wire.Let me know what you find.
Sep 15, 2010 at 5:49 PM
