2001 Saturn L200 Condenser discharge line
2001 SATURN L200
78,000 MILES • 4 CYL • FWD • AUTOMATIC
DDAVIS0323
I can see moisure collecting on the passenger side floor board. I believe it is from the air conditioner and possibly due to the condensation discharge hose being blocked. The fluid is clear and has no smell. How can I tell if the discharge hose for condensation is the cause?
Jul 12, 2010 at 8:42 AM
DDAVIS0323
Found the discharge hose for the ac unit. Located on firewall about 20" centered from top... It's a small rubber hose and after sqeezing it several times the system probably drained a pint + of clear water... I will monitor to see if this was the cause of the water under the front floor mats.
Jul 12, 2010 at 10:17 AM
SATURNTECH9
  • 30,869 POSTS
First of all thank you so much for your donation.Yes you found the a/c drain and it sound's like it was plugged.If your getting just water inside the car then the drain being caused is the number one reason.What you need to is unbolt where you were squeezing it remove it and clean it off the car to make sure you don't get more water in the car.That's the best way to clean it.
Jul 12, 2010 at 3:00 PM
