2002 Saturn L100 Parking Lamp Relay Switch Buzzing
2002 SATURN L100
252,000 MILES • 4 CYL • FWD • AUTOMATIC
BHOARD
On my 2002 Saturn L-100, the parking lamp relay will buzz/chatter at random intervals. This is the relay in the electrical area at the base of the driver-side door.
It does not seem to matter if the keys are in the ignition or not, but I find this happening most often in the evening when I can see the parking lamps partially lit out my driveway.
Its also important to note that while the parking relay buzzes, the interior dome lights, shifter light, radio and instrumental panel lights flicker and flash, but never come on completely. The exterior lights (parking lights and license plate) come on too, but are much more dim than normal. I'd say that they're about 50% of full ON brightness.
I can stop the buzzing by keying the headlight switch from AUTO to ON (either position). The buzzing only happens when the lights system is set to AUTO.
This model does have the photo voltaic sensor on the dash, and last weekend I replaced on the steering column headlight switch with a new OEM part in an attempt to fix this problem. That did not help.
It has been cold in my home state the past few months, but there doesn't seem to be a direct correlation between the temperature and the times when this happens and doesn't.
The problem also happens when the car is in park versus drive. There's no difference.
The only way I can STOP it when it happens is to key the lights to ON or pull the parking lamp relay. The relay is pulled right now.
I've also tried swapping the relays around to see if I had a bad relay, but the buzzing happens no matter which of the same type of relay I put in there.
I do not have any BCM symptoms at this point. My door locks, truck release and everything work fine. Alarm works fine too.
Help?
Mar 3, 2010 at 2:27 PM
SATURNTECH9
  • 30,869 POSTS
flashing interior lights is a bad bcm syptom is ur fuel gauge keyless entry if u have it working ok.also have seen headlights act up with a bad bcm.real common bcms going out on that yr and the other yr saturns.thats why i have so many tester bcms all the ones i have replaced.let me know what u find.
Mar 3, 2010 at 2:45 PM
