Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Saturn
L100
Engine
Symptoms
Oil Leak
2002 Saturn L100 oil leak in engine
2002 SATURN L100
97,000 MILES • 4 CYL • 2WD • AUTOMATIC
SPITTIN
MEMBER
FOLLOW
what kind of repairs would I need if oil is leaking under the engine and the seal in the back of the engine?
Jun 29, 2010 at 4:04 PM
SATURNTECH9
CERTIFIED EXPERT
So are you saying the rear main is leaking?The seal around the crank shaft where the transmission bolts up?
Jun 29, 2010 at 4:13 PM
SPITTIN
MEMBER
yes
Jun 29, 2010 at 5:30 PM
SATURNTECH9
CERTIFIED EXPERT
8.2hrs labor time's shop labor rate.Plus alignment and the seal and transmission fluid etc.
Jun 30, 2010 at 12:43 AM
