2002 Saturn L100 Dash lights are crazy
2002 SATURN L100
12,600 MILES • 4 CYL • 2WD • AUTOMATIC
AOMJIM
Minor accident, literally no visible damage, but afterwards the ABS, Airbag, and Service engine soon came on and would not go out. Upon moving vehicle to side of road, we though all was well, then it would not go back into any gear. I did manually shift out of park removing the boot and rasing the white gear. When I got home, I played around with it. I turned the headlamps from the auto position to on and the trasnmission would then change gears, put lights back to Auto and the gears will not shift. Is this a BCM problem or just a resistor or snesor for DRL?
OH looks like the A/C stopped working too.
Jan 2, 2010 at 10:49 PM
SATURNTECH9
  • 30,869 POSTS
If this all happened since the accident I have never seen a bcm go bad from that but I have seen a bad bcm lock the shifter like that though.most common cause I have seen to lock the shifter though is a blown parking light fuse I would start there Its in the underhood fuse box if it's not blown I would make sure it has power going to it u may have damaged wires in the accident.let me know what u find.
Jan 3, 2010 at 11:43 AM
