2006 Saturn Ion fAILURE DUE TO BATTERY DRAINED TO 0.1 v
2006 SATURN ION
24,000 MILES • 4 CYL • 2WD • AUTOMATIC
JKELLOGG1
Could a battery being drained to 0.1 volts (parking lights left on), then installing new battery cause a transmission problrm? Problem being -- xmission not shifting up and check engine light being on. Check light off before battery drain, car pulled (in tow mode) behind motor home approx 1 mile, battery replaced then check light on.
Jun 29, 2010 at 4:06 PM
Have the computer scanned for code/s-you have a problem within the engine management system that caused the CEL to turn on-This is your starting point of diagnosis,finding out what's going on
Jun 29, 2010 at 4:09 PM
JKELLOGG1
CAR IS AT TRANSMISSION REPAIR SHOP. WAITING FOR DIAGONISTIC RESULTS NOW.
Jun 29, 2010 at 4:28 PM
JKELLOGG1
Would towing (in tow mode behind motor home) with a dead battery cause transmission damage?
Jun 29, 2010 at 4:57 PM
If its in the tow mode there's shouldn't be a problem-dead battery will cause the computer to lose ist memory could be the transmission has to relearn itself
Jun 29, 2010 at 5:32 PM
