2005 Saturn Ion Clutch peddle
2005 SATURN ION
BILL1959
2005 Saturn Ion 4 cyl Two Wheel Drive Manual
The clutch peddle has no play in it and the car is hard to shift. Even when clutch peddle is fully depressed the car will go
Jan 6, 2010 at 9:17 PM
SATURNTECH9
  • 30,869 POSTS
if u have the clutch pedal all the way to the floor and its still not releasing then u ethier have a problem with the hydralics or the clutch itself like the pressure plate etc.are u sure theres no play when ur pushing on the clutch before the pedal gets hard.also check to make sure the floor amt isnt under the pedal causuing it to not fully release.let me know what u find.also look under the car and make sure u cant see anything leaking like fluid from the clutch from the trans.
Jan 7, 2010 at 11:29 AM
