back up lights
2004 SATURN ION
50,000 MILES • 4 CYL • FWD • MANUAL
GHWILKERSON
Neither of the back up lights work. I suspect a fuse, but can't find which one controls them in my owners manual.
Jan 23, 2009 at 10:37 AM
BRIAN 1
  • 1,030 POSTS
check fuse #15 in the underhood fuse block,its in there.post back with what you find.
Jan 23, 2009 at 4:10 PM
GHWILKERSON
I checked #15 as well as the other 2 associated with back up switch. All 3 are good.
Jan 23, 2009 at 8:24 PM
BRIAN 1
  • 1,030 POSTS
next step is Disconnect the backup lamp switch connector, for manual transaxle or the park neutral position switch connector for automatic transaxle.
Turn ON the ignition, with the engine OFF.
Probe the backup lamp supply voltage circuit of the connector with a test lamp that is connected to a good ground. see if you have power here.(you might have a problem with the backup lamp switch assembly) also first remove on of the reverse light bulbs and put it in reverse and see if there is power at one or both sockets.could even have 2 blown bulbs.post back with what you find.
Jan 23, 2009 at 8:39 PM
TRAVIS JONES
  • 24 POSTS
Reverse lights inoperable. Fuse fifteen is good replaced with a new one anyway. Getting no voltage at the bulb. Removed switch and with a multi-meter the resistance changes when the switch is depressed.
May 24, 2020 at 1:41 PM (Merged)
CARADIODOC
  • 34,306 POSTS
Check for twelve volts on both test points on fuse fifteen with the ignition switch in the "run" position. If you have that, check for twelve volts on the pink wire at the switch. Back-probe that wire in the connector with it plugged in, if possible, and when shifted to "reverse". If the connector is sealed and you have to unplug it to take the reading, do that with a test light, not a digital voltmeter.
Next, check for twelve volts by back-probing on the light green wire when shifted to "reverse". If you have it there, there's a break in that wire between that point and the splice where the wire splits into two circuits.
FELDMAN78
Could you tell me where the back up light switch is located?
SATURNTECH9
  • 30,869 POSTS
https://www.2carpros.com/forum/automotive_pictures/416332_2003_ion_back_up_light_switch_1.jpg
The number one connector in the diagram plug's into the back up light switch.
FELDMAN78
Thank you for the picture. This is located on the front driver side behind tire?
SATURNTECH9
  • 30,869 POSTS
Yes it's behind the drivers side tire area turn the key to the run postion with the engine not running unplug the back up switch jump the connector that goes to back up switch across the two terminals.The back up lights should come on if they do but don't with the connector plugged in and the car in reverse then you have a bad back up light switch.I have seen a lot of back up light switches on those.
WISCONSIN_SATURN_OWNER
  • 7 POSTS
hi i have the same question, only i have a saturn ion 2004. is the switch located in the same place as the 2003?
SATURNTECH9
  • 30,869 POSTS
Yes it would be the same place.
STEVERUM
back up lights won't work.
JDL
  • 16,098 POSTS
Did you check the backup lamp fuse, check for voltage, goes hot when you turn the key on. Also, check backup lamp switch, on transaxle, left side of engine compartment.
