Check for twelve volts on both test points on fuse fifteen with the ignition switch in the "run" position. If you have that, check for twelve volts on the pink wire at the switch. Back-probe that wire in the connector with it plugged in, if possible, and when shifted to "reverse". If the connector is sealed and you have to unplug it to take the reading, do that with a test light, not a digital voltmeter.
Next, check for twelve volts by back-probing on the light green wire when shifted to "reverse". If you have it there, there's a break in that wire between that point and the splice where the wire splits into two circuits.
May 24, 2020 at 1:41 PM
(Merged)
