What could cause the driver's window to be stuck in the down position?
Sep 3, 2010 at 9:18 AM
SATURNTECH9
CERTIFIED EXPERT
A bad switch or most likely a bad window motor.When you push the window switch to the up position if you put your ear on the drivers side door can you hear a clicking noise in the door?Also do you have a multimeter?
