2003 Saturn Ion Turn and Hazard Lights
2003 SATURN ION
JUSTCUR
  • 4 POSTS
Electrical problem
2003 Saturn Ion 4 cyl Two Wheel Drive Manual
At times my turn signal lights or the Hazard lights come on without being switched on. They will not turn off, until the car is stopped and the ignition is switched off and even then it may take a while. If I apply the brakes they will be off during that time. This seems to happen at night.
Thanks
Jan 21, 2010 at 1:39 PM
BLACKOP555
  • 10,386 POSTS
soudns to me like you may have a faulty turn signal/multifunction switch would really be the only thing that would cause it to turn on and off. and even with the vehicle off. you can pull the relay first and then check to see if your getting voltage to it when they would normally turn on if so you should replace the switch
Jan 21, 2010 at 5:05 PM
