Engine Cooling problem
2003 Saturn Ion Automatic 65000 miles
What would be a reason that the fan motor would stop working therefore allowing the engine to overheat. i had noticed when the car ran hot that the fan was not turning. The next day I checked the wiring connection (unplugged and used test light) and was getting power to the motor. When I plugged it back up the fan started. If the heat sensor is bad would it stop the motor for some reason?
Aug 18, 2009 at 8:40 AM
