The only switch left I could located is the engine coolant level switch. I know what you're trying to say I assume its the engine temperature gauge switch that signals the computer to fire up the cooling fan thru a relay on a given temperature.
(basicly i still have the coolant temp sensor in the radiator but the wires and the connector was torn out,
I want you to identify the wire colors on the cooling fan motor and we'll tap in somewhere temporary to fire up the cooling till you find that wire
Also is this an XE or XR model astra?
Oct 27, 2009 at 10:11 PM
