It is part of the transmission range switch. If you have the common transmission it is mounted on the outside of the transmission over the manual selector shaft as shown in the first picture. If you have the heavy duty truck with the optional Allison transmission it is inside the transmission and the selector shaft goes through it into the valve body. That is the second picture. What is the issue that is telling you it needs replacement?
Apr 29, 2018 at 7:20 PM
