Someone used a regular metal key without a chip in it and put my car listed above into safe mode?
2010 VOLKSWAGEN JETTA
140,000 MILES • 2.5L • 5 CYL • 2WD • AUTOMATIC
SHIVER9
  • 6 POSTS
I have one original key fob, but it still isn’t working.
Sep 3, 2023 at 3:17 PM
Do you have the original key as well? Also does the security light flash when you try to crank the engine over. If so, let's try a hard system reboot.
This guide will help:
https://www.2carpros.com/articles/step-by-step-guide-performing-a-hard-system-reboot-for-your-vehicles-electronics-systems
If this doesn't work let's do a CAN scan. You can get a CAN scanner (Controller Area Network) which will work on most cars from Amazon.
Here is a video to show you how:
https://youtu.be/u-4syLc-ifQ
Please go over these guides and get back to us.
Sep 4, 2023 at 12:06 PM
SHIVER9
  • 6 POSTS
I lost one of the key fobs and a locksmith tried to start it with just a plain key (no chip) so it went into safe mode. I have the second key fob but so far, it’s not working. It tells me it’s the #2 fob. I lost the #1 fob. I have charged it fully and let it sit in on position for 2 hours but it’s still not taking it out of safe mode. I’m trying to avoid towing it to dealer.
Sep 4, 2023 at 12:23 PM
SHIVER9
  • 6 POSTS
Both key fobs are VW fobs that I got with it when I bought it.
Sep 4, 2023 at 12:24 PM
SHIVER9
  • 6 POSTS
I don’t want to invest in a scanner I was hoping for an easier fix somehow since I do have one fob that’s the original.
Sep 4, 2023 at 12:25 PM
You need the correct key; the fobs will not allow the car to start without the correct key. What do you use to try and crank the car over, the same key with no chip? You can have a mobile locksmith come out to do the job/program the ignition key it should cost about $250.00.
Sep 5, 2023 at 10:59 AM
Sep 5, 2023 at 11:00 AM
SHIVER9
  • 6 POSTS
Yes thank you.
Sep 5, 2023 at 11:01 AM
Please let me know what happens.
Sep 6, 2023 at 9:39 AM
SHIVER9
  • 6 POSTS
I’m still waiting for a locksmith to come help me. He’s supposed to be here today.
Sep 6, 2023 at 1:22 PM
