2000 Saab
2000 SAAB
DAVIDONE
Transmission problem
2000 Saab Front Wheel Drive Automatic 46,000 miles
when i put my foot down to pull away at lights etc the car does not move then after a few seconds the car pulls forward and drives normally through the gears it does not happen all the time but is sure to happen at least once on a journey and usually more than once in any given journey . its a saab 93 turbo.on inspection under the car there seems to be a minor leak of drive fluid from around the bottom of the transmission dipstick .the fluid seems to be up to correct level .
Dec 2, 2007 at 4:29 PM
2CARPRO JACK
  • 11,533 POSTS
Then something inside the trans is having a problem. Is the check engine light on? Might want to have a trans shop look at it before the problem develops into something worse.
Dec 3, 2007 at 7:52 AM
