1997 Saab 900 faulty starter ignition switch
1997 SAAB 900
CAROLANNFITCH
Engine Mechanical problem
1997 Saab 900 4 cyl All Wheel Drive Automatic 180K miles
I'm not sure on the cylinders or the "all wheel drive" on my 1997 Saab 900SE Turbo. Problem: I have a bad starter ignition switch that I've been babying for a couple of mo's. I start the car then manually switch it from start to on. Was working fine then a couple of weeks ago my battery kept dying out, overnight mostly but also other times when car was turned off for a few hours. Fine after a jump. Had tested at Adv. Auto and ALL checked out fine. Battery is still draining on me but not to completely dead, now also the car doesn't want to start. It tries over and over to turn over and won't unless I completely re-charge the battery. Do you think my faulty starter ignition switch is creating more problems for me? As I said, the computer test says that starter, battery & alternator are all fine. I plan on getting the new ignition switch in a couple of weeks but can't right now. Also I tried disconnecting the battery when the car was not in use and that doesn't help. Still just turns over and over and won't start until I hook up the charger for a few minutes. Thank you! I have more Saab stories but this is my immediate problem!!
Sep 29, 2009 at 3:02 PM
DAVE H
  • 13,384 POSTS
start by replacing the battery !
Sep 30, 2009 at 9:45 PM
CAROLANNFITCH
Thanks Dave! I actually broke down and went to my mechanic this morning and he told me the battery had a bad cell! I was sure it wasn't the battery since Adv. Auto tested it and told me it was FINE!! Well, it wasn't, and thankfully it was still covered under warranty at that same Adv. Auto so I got a new one for free! Hmmm... wonder why they didn't tell me that in the first place?? All is well now, for now...I can't believe I struggled with that for a couple of weeks, asking strangers to jump me on a regular basis, ha!ha! all because they told me the battery was perfectly fine! Oh well, thank you very much though!
[ihttps://www.2carpros.com/forum/automotive_pictures/415442_carol_new_1.jpg[/img]
Oct 1, 2009 at 12:26 AM
