Engine Cooling problem
1997 Saab 900 Front Wheel Drive Automatic 121000 miles
Hello there,
I recently had an oil change and right afterward, both coolant and oil have been leaking.
I noticed that the mechanic filled the coolant tank right up to the cap. Is this right? Could the coolant just be overflowing to the ground because it is too full? There is a big puddle on the ground every morning but the coolant tank is stiil filled way high.
Also, oil is leaking from a bolt (?) on the oil pan (?).
I'm filling it with a little under half a quart a day when I drive it to keep the level up.
If I don't drive it, the oil leak is very small, if at all. If I don't drive it, the oil level stays within the normal range.
Do I have to change the oil pan?
Thanks a lot for your help!!!
Hello there,
Feb 2, 2010 at 3:29 PM
