1996 Saab 900 starter motor
1996 SAAB 900
PAKKA
Electrical problem
1996 Saab 900 6 cyl Front Wheel Drive Manual
I Have a 1996 Saab 900s 5 speed manual
selonoid may have died
can you please tell me when you crank the saab to start and turn over it makes a whizzing zipping noise is that the starter motor gone or selonoid or both or is it something else
Thanks
Apr 12, 2009 at 10:15 PM
DAVE H
  • 13,384 POSTS
replce the starter motor and check the flywheel teeth when starter is removed from vehicle !
https://www.2carpros.com/forum/automotive_pictures/266999_saab_6.jpg
Apr 24, 2009 at 4:07 AM
PAKKA
not the starter motor inspected timing belt and it had threaded on outside not in half Fraying. but the tensioner had froze. mechanic has been replaced timing belt kit and still wont start. She turns over and back fires.
Apr 24, 2009 at 7:14 AM
DAVE H
  • 13,384 POSTS
Did you check for bent valves ?? compression test the cylinders .. or you could be a tooth off on the timing !!
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_565.png
Apr 25, 2009 at 6:51 AM
