1994 Saab 900 ignition cylinder
1994 SAAB 900
130,000 MILES • 4 CYL • 2WD • AUTOMATIC
JPL4257
what is easiest way to replace faulty ignition cylinder? I wouldn't mind having to use a toggle switch as car is my winter beater .
Dec 30, 2009 at 5:28 PM
KHLOW2008
  • 41,814 POSTS
Hi jpl4257,
Thank you for the donation.
I believe you mean the ignition switch. Even if you use a toggle switch, you would need to get to the wires. Here are a description of the removal procedures.
IGNITION SWITCH
Removal & Installation
1. Disconnect battery. Remove passenger seat. Remove center console and fold back carpet. Remove heater duct. Disconnect electrical wires to ignition switch, reverse light and inhibitor switch (automatic transmission models).
2. On automatic transmission models, make a reference mark on shifter cable and disconnect. On all models, remove gear selector housing bolts and lay selector housing on side. Remove ignition switch screws and remove ignition switch.
3. To install, align ignition switch with lock assembly and install. To complete installation, reverse removal procedure.
© 2008 Mitchell Repair Information Co., LLC.
Dec 31, 2009 at 10:24 AM
