I get a dtc code of P1110 which is manufacturer fuel air metering.What is this and is it something I can fix myself?
Jun 29, 2009 at 3:41 PM
MNTHNY4
CERTIFIED EXPERT
CHECK FOR VACUUM LEAK IN CHARGE AIR BYPASS VALVE ,valve located to the back mount to firewall ,should have a couple small vacuum type hoses plugs on to it ,one may have come loose ,or hose need replaicing.
