2001 Saab 9-5 Check Engine Light Flashed and Car Died
2001 SAAB 9-5
128,000 MILES • 4 CYL • FWD • AUTOMATIC
JCDKEL
  • 7 POSTS
My check engine light was on for a period of time, I had just completed some repairs, new battery, new heater bypass valve, and oil change the day before, the check engine went out after completing these repairs, started car in AM and heard wineing sound made sure that oil & water levels were ok, as I drove sound went away, drove for about 75 miles and check engine light started to flash and then car died, oil & water levels still ok, car will start and idle rough then shut down when try to accelerate, also turbo gauge will pin to top then drop. thinking that turbo went out, but not sure... is there any way to make sure it is just turbo and not anything internal???
Dec 18, 2009 at 9:05 AM
MNTHNY4
  • 612 POSTS
best to get codes read ,do that at any advance auto stores & post back codes ,but anyways u sound like u have a throttle body problem & a DI cassette fault ,the reason why the eng light went out was because u disconnected the battery ,but fault was still present & eng light reset with new drive cycle ,so get codes read & i can better help u ,good luck.
Dec 18, 2009 at 11:33 AM
JCDKEL
  • 7 POSTS
having car towed to local repair shop inwhich they specialize in SAAB etc. once I get codes will post... thanks for the direction !
Dec 18, 2009 at 12:22 PM
MNTHNY4
  • 612 POSTS
u r welcome ,just post back with codes ,& i can tell u what need repaired .
Dec 18, 2009 at 2:51 PM
JCDKEL
  • 7 POSTS
Repair shop said that it was a lose concetion of air intake to throttel body, easy repair, suggested that i replace DI and numerous other issues, motor mounts, cat converter, service manager advised that ok to drive but long term would be best to try and get rid of auto as long term would cost more than auto worth....
Dec 21, 2009 at 5:39 PM
