2000 Saab 9-5 timing belt
2000 SAAB 9-5
MEDINA2118
Engine Mechanical problem
2000 Saab 9-5 6 cyl Two Wheel Drive Automatic
Replacing timing belt didnot mark cam pully to the cam shaft unknow ther is more than one way to reinstall,I need to know the correct set for the cam pully, note
(cam shaft has a pin guide the pully has one long slot it get go any way but which is the rigth side)
Oct 18, 2010 at 12:28 PM
MNTHNY4
  • 612 POSTS
ok cams number from back of engine to the front of car so u have cams 1,2 3 & #4 at the front ,on the cams there r pins ,cams 1 , 2 & 4 pins should be pointing up in your face ,& cam #3 pin should be pointing down to the ground ,now u can fit spockets taking note to check the number on them as per the cam been fitted to ,good luck post back if u need more help .
Oct 19, 2010 at 8:13 PM
