Engine Mechanical problem
2000 Saab 9-5 4 cyl Front Wheel Drive Automatic
I bought my 2000 Saab in february of this year. Three weeks ago i had to replace my battery. After I did this my car was functioning fine. Then two weeks later I needed to replace my power steering pump. Once i picked my car up from the shop, i stopped to get gas, and my car would crank but not turn over. I called the shop since i was less than a mile away. They sent out a technician to diagnose what was going on. All the technician did was jiggle the battery cables and while the other technician tried to start my car. The car successfully turned over. Then one week or so later I was leaving my apt. and the car would not turn over. The car revs and cranks and tries to turn over but it will not. I am not sure what the problem may be. I currently do not have the factory battery cables installed on my car. Should I buy a negative battery cable from ebay? And if I do, is there a way that I could install it myself?
Jun 26, 2010 at 12:02 PM
