2000 Saab 9-5 Engine noise After Head Gasket change.
2000 SAAB 9-5
171,000 MILES • 4 CYL • 2WD • AUTOMATIC
LOVEUEVOL
Hi, My Saab Engine Got Over Heated & was forced to change head gas ket and do Head facing. After fixing Back Every thing engine runs ok and performance also look good, except when accelerating fast engine will make oooo sound no power like earlier.
The engine when idealing it is havieng noise like some thing rubbing or dont know.
Could you also please tell me the arangment for camshaft nutes and holder fixing sequense may be i have mixed them up.
Feb 24, 2009 at 11:27 AM
DEREKOLIVEIRA
  • 23 POSTS
May be timing is not correct(less power);chain too much loose,bearing cap and bolts monted in a wrong place(check oil pressure light/sensor if is good),check def.cods!
Do you want assemblig Schedule for camshafts?(clarify)
Mar 22, 2009 at 4:36 PM
