1999 Saab 9-5 Replace fuel pump
1999 SAAB 9-5
135,000 MILES • 4 CYL • 2WD • AUTOMATIC
VVKERZHA
How to replace a fuel pump in SAAB 95 1999 ?
Feb 4, 2009 at 2:43 PM
FACTORYJACK
  • 4,159 POSTS
Under the rear seat is an access panel, round silver disc with black border, remove and you'll see the lines that enter. You willl need to disconnect the lines carefully, as if they break, it is not good. Remove the brown toothed ring, and lift up on the pump module assembly. Tilt and twist to remove being cautious not to spill fuel on interior. The pump will be serviced as the entire module w/ sender and float.
Feb 4, 2009 at 9:58 PM
