1999 Saab 9-5 INTERIOR FAN/BLOWER STOPPED
1999 SAAB 9-5
115,000 MILES • 4 CYL • FWD • AUTOMATIC
ROBOFLOCKS
i CHECKED ALL FUSES AND APPEAR OK
WANT TO KNOW WHERE THE BLOWER IS LOCATED AND HOW DIFICULT TO CHANGE
Jan 20, 2009 at 7:48 PM
DEREKOLIVEIRA
  • 23 POSTS
Remove wiper blade arms;remove cover;remove wiper mecanism(unit);before you remove the engine give him power to check if is realy the engine!
Mar 22, 2009 at 5:23 PM
JSERRAT
Just to clarify: the blower motor motor is located in the bulkhead. It's accessible from the engine bay.
1 - remove wiper arms (tough to do): unscrew nut holding that secures the arm almost all the way off then use 2 channel lock pliers: upper jaw at the bottom of the wiper arm and top jaw on the nut, then tighten both pliers at the same time
2 - remove the bulkhead cover; pretty straightforward, you'll see
3 - about the center of the bulkhead, there's a small compartment for the blower motor; if I recall, it's mounted horizontally. disconnect wiring and remove
May 29, 2009 at 1:42 PM
