Had a coolant hose explode the other day. Fixed it but my mechanic was a little rough with wiring trying to get in there. I am hoping this is the case or I have a bad lifter and my engine is shot
I am running on 3 cylinders now and when it goes above 2000 RPM it shakes badly.
Here are the codes from the reader I got right now.
P0303 - Cylinder 3 Misfire
P1303 - Ignition System / Misfire
P1110 - Fuel/Air Metering
Please if someone can help. Was about to sell car AS IS but had a bad feeling it may be a mistake. I only bought this in May. This is my second overheating issue because of a hose, just FYI.
Thank you kindly in advance,
Gina
Gina
Jul 31, 2010 at 6:42 PM
