U SAY FREON IS FINE MAKE SURE CAUSE THIS IS VERY IMPORTANT ,WONT WORK IF NOT ENOUGH FREON IN SYSTEM SHOULD BE 87KG'S OR ALMOST 2 LBS ,ALSO DID U CHECK FOR POWER AT THE COMPRRESSOR ELECTRICAL WIRING [SINGLE RED WIRING GOING TO COMPRESSOR ] WITH ACC UNIT SET TO ON ,& I AM JUST NOTING U SAID U CHECKED FUSE ,RELAY IS LOCATED IN THE ENGINE BAY FUSE PANEL CHECK COVER FOR LOCATION ,ALSO IS YOUR ENGINE COOLANT TEMP SENSOR WORKING OK ,THIS WILL AFFECT A/C FUNCTION IF NOT WORKING GOOD ,GOOD LUCK.
Jul 19, 2010 at 1:43 PM
