Trunk lid will not open with key fob or button on inside of driver door. Will open only with a key. Can you suggest what to do? thanks...jim
Jul 16, 2010 at 12:29 PM
MNTHNY4
CERTIFIED EXPERT
u have a bad trunk lock motor ,get that checked ,or listen if u can hear movement from motor when u hit the key fob trunk button, if u can hear movement then u may need to refit rod that may have came loose ,good luck.
