U NEED TO FIRST REMOVE A/C VENTS ,U WILL NEED A PLASTIC REMOVAL TOOL FOR THIS PLUS & 3 NEEDLE TYPE PICKS TO REMOVE THE VENT NEAREST THE DOOR , CENTER VENT WILL COME APART IF U DONT REMOVE IT WITH CARE ,USING THE PLASTIC TOOL TO REMOVE CENTER VENT PUSH TOOL BETWEEN VENT & TOP SECTION OF RADIO FACEPLATE ,PULL ON ANY SECTION OF VENT THAT POPS OUT FIRST THEN WORK YOUR WAY DOWN ,AFTER THAT TAKE THE PICKS & USE A FLASH LIGHT TO LOOK INTO OUTER VENT FOR THE LOCKING CLIPS 2 WILL BE ON THE OUTER SIDE NEAR DOOR & 1 WILL BE NEAR TOP SECTION ON THE SIDE NEAR STEERING WHEEL ,LOOK FOR ALL THROUGH VENT ,STICK 1 PICK IN EACH CLIP AREA 3 IN ALL ,AFTER THAT TAKE HAND & PUSH PICKS OUTWARD & PULL VENT OUT AT THE SAME TIME ,AFTER REMOVING VENT ,TAKE YOUR TORX SCREW DRIVER & ALL SCREWS FROM RADIO & DASH PANEL ,NOTE REMOVE RADIO FIRST & DRIVE CAR & CHECK FOR NOISE ALSO DRIVE WITH CUPHOLDER IN THE OUT POSITION WHILE CHECKING TOO .GOOD LUCK
Jul 29, 2010 at 2:58 PM
