2006 Saab 9-3 repair Question Window / door lock
2006 SAAB 9-3
50,000 MILES • 4 CYL • FWD • AUTOMATIC
LIZT111
My drivers side window just stopped working. Won't go up or down. All other windows work fine. Also - driver's side door won't lock with the remote. All other doors lock. Any idea if it's the motor in the door or a fuse ???
Dec 11, 2009 at 6:32 PM
MNTHNY4
  • 612 POSTS
get the codes for drive side door control module checked ,u may have a bad module or just a software issue needing updating & re-adding to system also your door lock motor may be faullty ,ok check & do this open door fully between door end & door frame locate main wiring harness connector unplug for 10seconds reconnect ,now check function ,if still inop take to dealer for repairs.
Dec 14, 2009 at 7:29 AM
