convertible top problem
2006 SAAB 9-3
PECKENROTH
the top will not go down and a message is now on to take the car to the dealer for repair. I think there must be some way of resetting the system, my daughter put a lot of items in the trunk and this might have shut the system down.
Nov 21, 2009 at 10:49 AM
MNTHNY4
  • 612 POSTS
HEY what's up u sound like u have a conv top storage boot cable problem ,there is no reset per-say u can open top manually ,do u have your vehicle manual ,or it would be better to take to your local saab dealer ,notice i said saab dealer not your local mechanic ,this top uses a lot of hall effect type sensors if one is also out of place top will not work also ,so take to your saab dealer for repairs .
Nov 23, 2009 at 7:15 AM
SUSAN WALSH
Computer problem
2005 Saab 9-3 repair Question Automatic
My roof is intermittently refusing to go bake up on the dash the customize inst working either when this happens please help its going to rain tomorrow and i dont have a garage
Sue
Aug 6, 2019 at 3:11 PM (Merged)
MNTHNY4
  • 612 POSTS
do u have a owners manual ,if so use it to find info on how to manually close soft top ,u should also have a tool in the trunk to assist with this process .
ROCANDAV
is it possible to splice in another identical hose without much problem? Hydraulic Hose info taken off the hose: Parker Polyflex 263 DN2 WP 200 bar
(the 200 bar translates to about 2900 psi - is this the actual operating pressure?)
What fittings can be used for reattachment?
RIVERMIKERAT
  • 6,110 POSTS
You need the ones designed for whatever hydraulic fluid is being used and the pressure in use.
ROCANDAV
Saab dealer mentions to use Mineral Oil. I will most likely replace the entire line and not take a chance to splice in. I have contacted Parker (USA division) and see if a splice is even realistic.
Thanks for the help.
RIVERMIKERAT
  • 6,110 POSTS
Splices are normally not recommendable, especially at the pressure levels you mentioned above.
GREGFOX
Rocandav,
did you have any luck?
I was considering a splice as well, so I could use a tube with more resilience to being in the top down bent position longer.
at the pump, there looks to be Tube Stub Fittings. Does anyone know how they are connected? it looks like the pump plate holds them in, or do they screw into the plate?
TOM HOFF
saab 9/3 convertable soft top failure
ERNEST CLARK
  • 1,730 POSTS
What exactly is the failure. Does it not open at all, does it get stuck part way, does it not close???
GREGFOX
The line has a product number 263 DN2 WP 200 BAR, and a QC number QC 23077 07 3-Q-04. The line OD is 0.174-0.179. Parker Polyflex
the bend in the closed position is about 1" dia, and straight when oppen.
The cylinder connection in has an OD of 0.149. At the pump, what looks like Tube Stub Fitting, the OD of the fitting as it passes through the manifold plate, is 0.172. I'm not sure how they connect past this point howerver.
GREGFOX
The cylinder connection in has an OD of 0.149. At the pump, what looks like Tube Stub Fitting, the OD of the fitting as it passes through the manifold plate, is 0.172. I'm not sure how they connect past this point howerver. it is the lower connection
RIVERMIKERAT
  • 6,110 POSTS
greg; A hose that is more resilient is usually less able to handle higher pressures.
ROCANDAV
Gregfox
The thought was to replace an equivalent / capable line. If this line is approaching even 100 psi, you will need the right connections. Having worked in the Structural test engineer'g field, we used 3000 psi lines to run our Static and cyclic test (1500 psi if minimal loading). These pressures truly require correct connections (most ours were Stainless steel with sufficient rating). With our SAAB, I am just going to install the entire line (see Jim Ellis Saab Atlanta for a menagerie of parts with illustrations).
RIVERMIKERAT
  • 6,110 POSTS
That's what I would recommend.
Aug 6, 2019 at 3:12 PM (Merged)
NACHOGARCIA
Hello friend,
I am having exactly the same problem with my saab 93 2004 cabriolet. Do you remember where did you buy the hose and the part number?
Were you able to replace it on your own?
Thanks a million
Ignacio from Spain
TOMPALL
i was putting the top down and a piece a furniture was too high and the top hit it and stopped i also heard a bang. i got the top down and secured in front but the back is not seucred. i get no power at all for the top is their a fuse that might need to be replaced?
MNTHNY4
  • 612 POSTS
hey what's up ,1st r u getting a message on the sid display like [softtop failure] ,if not ,u will need to go through softtop manual mode closing ,use your owners manual for this ,also check main motor reservior fluid level ,checking from pip hole inside trunk at the inner back section more to the drivers side u may have blown a seal or a hydraulic hose ,and yes there is a fuse plus relays located on main hyd motor assembly ,but anyways there can be a series of issue that can cause the top to stop working ,best to take to a dealer or some one who knows about saab hyd softtop system function,sorry if info dont help .
RIVERMIKERAT
  • 6,110 POSTS
Hi Ignacio,
I would recommend searching for the given part numbers.
JOELZIMM
i have a slow leak in the hydraulics that operates my soft top. can someone tell me where the fluid reservoir is and how i can fill it up ? i have found what i think is the reservoir behind the back seat but i cannot figure out where to add the fluid.
thanks for the help - the deal wants $150 to fill it up ...
DOCFIXIT
  • 18,828 POSTS
That's it behind rear seat remove filler plug use funnel to fill see diagram
https://www.2carpros.com/forum/automotive_pictures/198357_Graphic_507.jpg
JDCRAVENS
1999 Saab 9-3 repair Question Front Wheel Drive Automatic
HOW DO i REPAIR THE CONVERTIBLE TOP
Aug 6, 2019 at 3:13 PM (Merged)
SCOTT FIADINO
Electrical problem
1999 Saab 9-3 repair Question 4 cyl Two Wheel Drive Manual 119k miles
roof will not retract> Everything sounds normal nothing out of the ordinary....then completion bell sounds without roof rretraction.
MNTHNY4
  • 612 POSTS
u will need to check hydraulic fluid reservior ,check from pip hole located inside trunk ,if fluid level is good then u need to check intermediate switch located on driver side ,small swiitch above hyd cylinders in corner ,check if switch as bent arm ,if so u will need to replace but if u r good u may be able to straighten arm without breaking it good luck ,check your owner manual on how to manually work softtop ,to release 5th bow & fold down top .
