2005 Saab 9-3 repair Question how can i make the brake calip
2005 SAAB 9-3
MDAVIS1734
2005 Saab 9-3 repair Question Front Wheel Drive
I am replacing pads on the car, and I cannot get the brake caliper piston to retract enough to get the caliper back on with the new pads. Any suggestion?
Feb 21, 2010 at 4:25 PM
MNTHNY4
  • 612 POSTS
u did not say which pads u r replacing ,but the only piston that will need a special tool or some know how to retract in is the rear calipers, make sure hand brake is off ,if u do not have special tool ,u will need a pair needle nose plyers ,pull caliper bleeder screw ,now take needle nose & start turning piston in a clockwise direction while pushing in ,good luck.
Feb 22, 2010 at 8:52 AM
