2005 Saab 9-3 repair Question Battery will drain overnight
2005 SAAB 9-3
111,111 MILES • 4 CYL • FWD • AUTOMATIC
FRANCINEGOWEN
MEMBER
1 POST
FOLLOW
What pulls the most voltage from inside the car? I have have in down to something that is with the door or in the dash.
Feb 12, 2010 at 9:44 AM
MNTHNY4
CERTIFIED EXPERT
check your ignition switch or your radio amp ,check if any fluids spilled into your ignition switch or if your radio amp under your drivers seat got wet at some time ,also get the battery check for a bad cell ,also check if u hear the engine cooling fans running with key out for a extended time ,good luck .
