2004 Saab 9-3 repair Question Windows
2004 SAAB 9-3
92,000 MILES • 4 CYL • FWD • AUTOMATIC
ED3362
When I push the window up button, many times the front window will keep returning to down. This happens mostly on both front windows.
Aug 13, 2010 at 8:49 AM
MNTHNY4
  • 612 POSTS
u need to reset anti-pinch function ,did u take to dealer to have door modules software updated to address anti-pinch function ,if not check with your saab dealer ,but if u did already have this done ,then just unplug both front door main wiring harness for a few seconds ,& that is the connector between the door jams near door stop mechanism ,refit connector & run window full up & full down 2 -3 times holding the button in the up postion for a few second after running up & down for 2 times until u hear a beep sound ,do that for both window & u r good to go ,but if u can't do this then u can close window manually by holding down window lock out button & at the same time pulling up on the window button for the window u want to get closed .
Aug 13, 2010 at 11:27 AM
