Driver side window was stuck half way up and when you would push the button to raise or lower the window you would hear a grinding sound.
I was able to get the door panel apart, and found the problem, the wires that are used to raise and lower the window had come off of the pulley.
I was able to get the window back up, but can't seem to get the pulley re-strung correctly to allow the window to function. I can't a manual anywhere on how this should be done correctly.
Aug 24, 2008 at 12:46 PM
