2004 Saab 9-3 repair Question Drivers side window won't go u
2004 SAAB 9-3
55,000 MILES • 4 CYL • 2WD • AUTOMATIC
HATALLAM
Driver side window was stuck half way up and when you would push the button to raise or lower the window you would hear a grinding sound.
I was able to get the door panel apart, and found the problem, the wires that are used to raise and lower the window had come off of the pulley.
I was able to get the window back up, but can't seem to get the pulley re-strung correctly to allow the window to function. I can't a manual anywhere on how this should be done correctly.
Aug 24, 2008 at 12:46 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
Thank you for the donation,
i have found some information on the window set up but i need to know if you have an Aero, Arc or Linear, as there may be some differences in the set up.
Mark (mhpautos)
Aug 26, 2008 at 4:53 AM
HATALLAM
It is a 9-3 Linear
Aug 26, 2008 at 9:21 PM
MHPAUTOS
  • 31,937 POSTS
Ok thanks,
i will check it out and send what we have.
mark (mhpautos)
Aug 26, 2008 at 9:47 PM
MHPAUTOS
  • 31,937 POSTS
Hi there, I have not a lot to offer as yet, here is what i have come across, i will keep looking and i hope that i came find something better for you. Mark (mhpautos)
https://www.2carpros.com/forum/automotive_pictures/61395_pic_1_7.jpg
https://www.2carpros.com/forum/automotive_pictures/61395_pic_2_3.jpg
https://www.2carpros.com/forum/automotive_pictures/61395_snap_1_11.jpg
Aug 27, 2008 at 5:11 AM
HATALLAM
Hi Mark,
Thanks for this information. I can get the motor out OK. However the wires that lift the window that I'm having problems with. Is there a diagram that shows how they attach to the window and how they are to be strung on the pulley that the motor connects to?
thanks,
Mike
Aug 27, 2008 at 7:29 PM
MHPAUTOS
  • 31,937 POSTS
Hi there,
there are is over 100 pics on the glass section in the data base i have access to , so i will have to check through carefully and see if i can find that for you.
Mark (mhpautos)
Aug 27, 2008 at 7:50 PM
