2003 Saab 9-3 repair Question Xenon headlight bulb replaceme
2003 SAAB 9-3
100,000 MILES • 4 CYL • FWD • MANUAL
DADDYMIKE
How do I replace the xenon headlight bulb passenger side on 2003 saab 9-3 arc?
Jan 12, 2010 at 6:42 PM
MNTHNY4
  • 612 POSTS
remove headlamp rubber boot cover from bulb section at back of lamp assembly,now turn ballist clockwise to remove unplug wiring from ballist 1st ,than bulb has a wire type lock pull & remove bulb but pay attention to how bulb is set in housing ,also pay attention to how ballist was taken off ,the ballist also has a lock if that shifts u will not be able to refit correctly ,if after u replace bulb & light still inop u will need to replace the control unit mounted under the bottom side of said lamp assembly ,good luck.remember to refit wiring to ballist .
Jan 13, 2010 at 8:06 AM
LATONA
  • 8 POSTS
we have HID ALL IN ONE for 2003 Saab 9-3.
Please click here to see it's advantage.
www.smart-hid.com
Jan 21, 2014 at 11:01 PM
